simple question about VTY
Answered Question
Jun 5th, 2009
Hi there,
when i want to configure ssh to be used in telnet ,do i need to enter the vty like using these commands:
(config)# line vty 0 1180
do i really need 1180 , and what does it refer to .
Correct Answer by Farrukh Haroon about 7 years 9 months ago
With newer IOS releases (relatively new), the number of VTY lines have been increased (from 5/16 to 1000+). You need to do 'transport input all' or 'transport input telnet ssh' on the lines to allow telnet & ssh together.
You can just configure as many lines as you need, for example lines 0 to 15 and leave the rest. This is a good template to secure IOS configurations, check the VTY configuration section:
http://www.cymru.com/Documents/secure-ios-template.html
Farrukh
Overall Rating: 3 (1 ratings)
Correct Answer
Farrukh Haroon Sat, 06/06/2009 - 23:37
  • Red, 2250 points or more
Farrukh
hkourbani Sun, 06/07/2009 - 22:32
thx man ,
quote :"You can just configure as many lines as you need"
That's exactly what i am looking for .
