mpls global route leaking
Jun 6th, 2009
Please find attached visio diagram ,
i want to leak a global route from router R4 to VRF between R3 and R5
R3 is in VRF and running rip with PE1R2,
Connectivity from R3 to R5 through vpn is fix no issues now i want to leak a global route (a loopback interface)from R4 to VRF in which R3 and R5 are.
the protocol in between PE and P and PE is OSPF.
What i shld configure.
Harold Ritter Sat, 06/06/2009 - 17:12
  • Cisco Employee,
Adam,
You can simply configure a VRF static route on PE1R2 and then redistribute static for the appropriate VRF context under the BGP process.
ip router vrf xyz 255.255.255.255 global
router bgp xxx
address-family ipv4 vrf xyz
redistribute static
Don't forget that if you want to have IP connectivity between R4 and let's say R3, you will also need to inject a route to R3 subnet(s) into the global routing table on PE1R2. You will need to specify the physical interface on the static route command as follow:
ip route
router ospf xxx
redistibute static subnet
adamgibs7 Sun, 06/07/2009 - 02:09
Hritter,
very good explanation,appreciate.
Hritter Now i can reach R4 loopback from R3 the route is present in vrf,but am not able to ping R3 subnet from R4 or PE1R2.The subnet between PE1R2 and R3 is 192.168.23.0 when i specify a staic route and redistribute it appears in routing table as such but it doesnt ping its own interface F1/0 on PE1R2 (192.168.23.2) which is assigned to vrf for R3.
PE1R2#sh ip route
Gateway of last resort is not set
C 192.168.24.0/24 is directly connected, FastEthernet2/0
O 192.168.9.0/24 [110/2] via 192.168.20.1, 00:25:55, FastEthernet0/0
O 192.168.10.0/24 [110/2] via 192.168.20.1, 00:25:55, FastEthernet0/0
192.168.4.0/32 is subnetted, 1 subnets
O 192.168.4.4 [110/2] via 192.168.24.4, 00:25:55, FastEthernet2/0
C 192.168.20.0/24 is directly connected, FastEthernet0/0
S 192.168.23.0/24 is directly connected, FastEthernet1/0
O 192.168.1.0/24 [110/3] via 192.168.20.1, 00:25:55, FastEthernet0/0
C 192.168.2.0/24 is directly connected, Loopback0.
192.168.23.0
f1/0
R3-----------PE1------P-PE2--R5
.3 .2 | f2/0
| .2
| 192.168.24.0
| .4
R4
Harold Ritter Sun, 06/07/2009 - 07:59
  • Cisco Employee,
Adam,
It is normal behavior for PE1R2 not to be able to ping R3 via the global as it should use the VRF to do so. Try pinging 192.168.23.2 from R4 using the loopback address as the source IP address. This should work, assuming that the route for the loopback address is correctly configured in the VRF.
adamgibs7 Sun, 06/07/2009 - 11:34
Hi Hritter,
Do click this for me i have done that,sometimes i dou't the GNS3 acting funny for me and spoiling my knowledge,pasting the sh ip route for R4
R4#sh ip route
C 192.168.24.0/24 is directly connected, FastEthernet1/0
C 192.168.4.0/24 is directly connected, Loopback1
O 192.168.20.0/24 [110/2] via 192.168.24.2, 00:00:15, FastEthernet1/0
O E2 192.168.23.0/24 [110/20] via 192.168.24.2, 00:00:15, FastEthernet1/0
O 192.168.2.0/24 [110/2] via 192.168.24.2, 00:00:15, FastEthernet1/0
As u can c the route:
am able to ping from the source address successfully but now i dont have a route in R3 for loopback it is present in R2,R1,R5 in VRF but not in R3 nd am not able to ping from R1 and R5,in morning route was present for R3 and successfully pinging but now when i started the GNS3 with saved config's the route disappear,
It should also ping from R1 and R5??? If am not wrong,the route is present but it is not pinging from R1 and R5.
All the way thanks for ur help,Awaiting for ur last reply
My CPU is reaching 100% and memmory is been over utilized by GNS3.
Harold Ritter Sun, 06/07/2009 - 15:02
  • Cisco Employee,
Adam,
You also need to make sure you redistribute the static VRF route (for R4 loopback address) into RIP so R3 receives it.
Harold Ritter Sun, 06/07/2009 - 15:06
  • Cisco Employee,
Adam,
You should also be able to ping R4 loopback address from R5 assuming the route to R5 source address has been installed and redistributed into the global as well.
adamgibs7 Mon, 06/08/2009 - 10:34
Hello Hritter,
I have redistributed the static VRF route in RIP and BGP but still R3 is not able to ping,I have done this today morning on physical switches still R3 is not able to ping,R3 is having route for loopback but still it is not pinging,
From R4 it is pinging the R2 VRF interface and vice versa but packets are getting drop 3/5. What could be the possible reason.
Just have a look on R2 configs,
version 12.4
no service timestamps debug uptime
no service timestamps log uptime
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf test
rd 100:20
route-target export 100:20
route-target import 100:20
interface Loopback0
ip address 192.168.2.2 255.255.255.0
ip ospf network point-to-point
interface FastEthernet0/0
ip address 192.168.20.2 255.255.255.0
duplex auto
speed auto
mpls ip
interface FastEthernet1/0
ip vrf forwarding test
ip address 192.168.23.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
ip address 192.168.24.2 255.255.255.0
duplex auto
speed auto
interface Serial3/0
no ip address
serial restart-delay 0
interface Serial3/1
no ip address
interface Serial3/2
no ip address
interface Serial3/3
no ip address
router ospf 1
router-id 192.168.2.2
log-adjacency-changes
redistribute static subnets
network 192.168.2.2 0.0.0.0 area 0
network 192.168.20.2 0.0.0.0 area 0
network 192.168.24.2 0.0.0.0 area 0
router rip
version 2
no auto-summary
address-family ipv4 vrf test
redistribute bgp 100 metric transparent
redistribut static metric transparent
network 192.168.23.0
no auto-summary
version 2
exit-address-family
router bgp 100
bgp router-id 192.168.2.2
bgp log-neighbor-changes
neighbor 192.168.1.1 remote-as 100
neighbor 192.168.1.1 update-source Loopback0
address-family ipv4
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 next-hop-self
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 192.168.1.1 send-community extended
exit-address-family
redistribute static
redistribute rip
no synchronization
exit-address-family
no ip http server
no ip forward-protocol nd
ip route 192.168.23.0 255.255.255.0 FastEthernet1/0
ip route vrf test 192.168.4.4 255.255.255.255 192.168.4.4 global
route-map static permit 10
match interface FastEthernet1/0
mpls ldp router-id Loopback0
control-plane
line con 0
line aux 0
line vty 0 4
no login
end
Harold Ritter Mon, 06/08/2009 - 16:55
  • Cisco Employee,
Adam,
- Does R3 have a route to R4 loopback address?
- Does R4 have a routes back to R3 source address?
If so, it should work as the configuration of PE1R2 looks good.
