ASA5505 IPSec/SSL services for users
Jun 6th, 2009
Quick question. Using a 5505 running 8.0(4) code, is is possible to allow a user to connect via IPSec as well as SVC?? In this particular instance clients are authenticated using LOCAL authentication. When I configure the user attributes I can either set the vpn-group-policy or use memberof and fill in a comma separated list of tunnels. If I have both the vpn-group-policy and the memberof defined (or just the vpn-group-policy) I can only connect via the SVC. If I only have the memberof defined I can only connect with the IPSec VPN Client. Is there no way to provide both services for users??
Farrukh Haroon Sun, 06/07/2009 - 00:07
Yes you can do this without any issues, can you post the sanitized configuration related to this?
Farrukh
