06-06-2009 07:08 PM
one of my netconfig job is getting failed with the following error message.
"Command(s) failed on the device Couldnot enter ENABLE Mode from USER Mode on Device. TFTP: Tftp is supported only for config mode commands. Could not detect protocols running on the device Could not synchronize RME archive with Device Config" . please help
LMS 3.0 RME 4.1.0
06-07-2009 10:19 AM
This error points to a problem entering enable mode on this device. Check your enable password credential in DCR, and make sure it's correct. If it is, and you're using telnet as a transport protocol, get a sniffer trace of all telnet traffic to the device when running the job. That should show you why the failure is occurring.
06-07-2009 02:59 PM
Hello, we are a group of purdue students that are doing a success case analysis over cisco as a company. We would really appreciate it if you take a few mintues to answer a couple of questions.
-Are you satisfied with the services provided with this company?
-What do you like/dislike the most about cisco?
