ASA 5520 Failover License?
Jun 7th, 2009
Hi every one.in our company we want to buy two ASA5520 with AIP-SSM-10 bundle for our site.i found this part number on cisco documents witch is ASA5520 and AIP-SSM-10 together.part number is=ASA5520-AIP10-K9.
my Questions from you experts:
1)i want to know that is there any license such as UR in this bundle to run Active/Active Senario between this ASA's?
(i didnt find in bundle details)
2)if i want to run Active/ACtive senario on asa5520 do i need to RU licenses for both ASA's or no just one RU is good to go?
Kureli Sankar Sun, 06/07/2009 - 11:41
Pls. read here;
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/failover.html#wp1053685
To run active/active failover you should be running multiple context mode.
To answer your qestions:
1. You need to get activation keys for active/active license for both ASAs. These need to be uploaded to the units with the activation-key command in config mode.
2. There is no FO, UR, etc in the ASA platform. You need the activation keys. sh ver from both unit should look identical for failover to work properly.
The licensed features (such as SSL VPN peers or security contexts, for example) on both security appliances participating in failover must be identical.
blackhat2020 Mon, 06/08/2009 - 04:13
thanks,i have another Question.with that bundle part number can i run active passive without geting HA activation license or no i need it even for Active/Passive? and where can i find HA Activation License partnumber?thanks
srikantganesh Tue, 06/09/2009 - 12:07
I think ASA 5520 comes with Security plus license by default now and that has the ability to do failover in active/passive or active/active (multiple context mode)
