can't test sdk services exemple
Jun 7th, 2009
Hi expert,
when i try to test sdk services from my ip communicator message host not found display.
i subscribe Ip phone to services,and i add services to my call manager.
but service is not visible from my ip communicator.
Please help.
irisrios Fri, 06/12/2009 - 14:26
  • Silver, 250 points or more
- Is the IPC on the same LAN as CCM or is there a firewall between IPC and CCM?
- What version of CallManager are you currently running including any service releases and/or engineering specials?
- What version of IP Communicator you are running. Is this the only IPC you have setup or are there other IPC that are having this problem.
