Remote Management - Console Access
Jun 7th, 2009
What are the options to remotely manage Cisco devices via console sessions such as Async interface (Octal cable) on a terminal server/router etc.
Overall Rating: 4 (1 ratings)
cisco_lad2004 Sun, 06/07/2009 - 11:41
  • Gold, 750 points or more
Correct !
Console access via access server. this can be either INband or Outband.
There are also some dial in modems with a SIM card as a quick fix.
Sam
tech_trac Sun, 06/07/2009 - 21:53
Are there different options within Async interface or the Octal cable types.
cisco_lad2004 Sun, 06/07/2009 - 23:09
octal cable goes on console port, its not ant different from the plain flat cable you get with new routers or switches.
Sam
