06-07-2009 05:45 PM - edited 03-06-2019 06:07 AM
How can I calculate the routers'usage of memory?
Example:
I entered "show proce mem" in the router,then ,
Router2821#show processes memory
Processor Pool Total: 213654736 Used: 9967864 Free: 203686872
I/O Pool Total: 10485760 Used: 2547456 Free: 7938304
What should I do next?
Solved! Go to Solution.
06-08-2009 04:42 AM
Hello Hu,
memory can be seen as used by two parts:
main memory
I/O memory
you can see the total amount of memory in sh ver output.
In your show output we can see:
Used: 9967864 Free: 203686872 of main mem
Used: 2547456 Free: 7938304 of I/0 memory
total I/O memory should be:
2547456 + 7938304 = 10485760 10 MB
total main memory:
9967864 + 203686872 = 213654736 bytes
Hope to help
Giuseppe
06-08-2009 10:28 PM
Hello Hu,
your understanding is correct the I/O memory is used to handle packets received and to be transmitted on the router interfaces and to host the software queues that can be associated to the interfaces.
the main memory is where IOS code runs and where all the used tables are: ip routing table, CEF table, ARP table and so on.
Hope to help
Giuseppe
06-08-2009 04:42 AM
Hello Hu,
main memory
I/O memory
total main memory:
Hope to help
Giuseppe
06-08-2009 05:39 PM
Thank you very much!
By the way, what does the I/O memory use for?
I think the main memory is a zone of memory where system's processes run,such as "ip input""exec line""DHCPD"etc.While the I/O memory is the I/O cache or other means?
Am I right?
06-08-2009 10:28 PM
Hello Hu,
Hope to help
Giuseppe
06-10-2009 01:19 AM
This really helps!
