Show crypto ipsec sa
Jun 7th, 2009
Hi all. I have applied a crypto map to an interface that is shut. But when i do sh crypto ipsec sa, i can see the entry for this interface as well. Although all counters are zero but i am confused why is it showing at all ?
If i only want to see active interfaces which are actually passing the traffic how can i see them ? is there anyway to exclude interfaces that are not active ?
Farrukh Haroon Tue, 06/09/2009 - 00:52
  • Red, 2250 points or more
There are a number of parameters avaialble in the 'show crypto ipsec sa' command to filter the output:
show crypto ipsec sa ?
address IPSEC SA table in (dest) address order
detail show counter detail
identity IPSEC SADB identity tree
interface Show info for specific interface
ipv6 Show IPv6 crypto IPsec SA info
map IPSEC SA table for a specific crypto map
peer Show peer sas
vrf VRF Routing/Forwarding instance
| Output modifiers
Also you can do something like
show crypto ipsec sa | include interface|tag|ident|encr|decr
Farrukh
