CSS 11501
Jun 8th, 2009
I have CSS11501 with SV sg0810106 (08.10.1.06) and i want to know what is latest IOS and software version
Version: sg0810106 (08.10.1.06)
Flash (Locked): 08.10.1.06
Flash (Operational): 08.10.1.06
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Overall Rating: 5 (2 ratings)
dario.didio Mon, 06/08/2009 - 00:40
  • Silver, 250 points or more
latest version in 8.10 is 8.10.5.03.
Latest versin in 8.20 is 8.20.3.03.
Release notes of 8.10 can be found here:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/release/note/RN810_X.html
Release notes of 8.20 can be found here: http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20/release/note/RN820_X.html
HTH,
Dario
iabobakr78 Wed, 06/24/2009 - 02:06
Thanks so much for your update.
How can I upgrade from 8.10 to 8.20 is it like upgrade Router IOS
iabobakr78 Fri, 06/26/2009 - 23:33
Dear Dario
Thanks so much for your updates. my question is there a different in operational between Version Sg8.10 and Sg8.20
dario.didio Sun, 06/28/2009 - 23:18
Normally no, 8.20 is an updated version with bug fixes but no additional features, so it should be identical to the 8.10.
Pls rate if this was helpful for you.
Cheers,
Dario
iabobakr78 Mon, 06/29/2009 - 01:15
Thanks so much Guys
So what I need to do configure FTP server and upload sg0820303.adi and is there anything else I should be aware before upgrading
dario.didio Mon, 06/29/2009 - 01:47
just follow the upgrade procedure and you will be fine :-)
if it doesn't work, just let us know.
Good luck,
Dario
