Catalyst 6500 single Supervisor with Advanced IP Services SSH IOS
Jun 8th, 2009
Why it is not possible to order IOS ADVANCED IP SERVICES SSH with Catalyst 6506 with single VS-S720-10G-3C supervisor ?
To be more precise - it is not possible to choose this IOS with single Supervisor in configuration tool.
Giuseppe Larosa Tue, 06/09/2009 - 23:11
  • Hall of Fame,
    Founding Member
Hello Savo,
this can be a software problem of configuration tool from a technical point of view your choices look like correct: I mean if you install a single VS-S720-10G-3C in 6506 chassis it should work.
I don't know if there is any marketing decision behind this.
You may want to contact your cisco representive to have a confirmation/explanation.
Hope to help
Giuseppe
bgroff Mon, 06/22/2009 - 19:56
It was an intentional decision on the part of Cisco to only include IP Base with a single supervisor in the 6506 VS bundle. You have the option of either ordering the bundle and adding IP Services via the Spare-CD route, or ordering without doing a bundle.
