Inter-VLAN routing
Answered Question
Jun 8th, 2009
Hi all,
For the moment, I have a very basic question: Does one always need a router while trying to route between multiple VLANs?
Obviously, my understanding is also that a VLAN is also equivalent to a subnet in the roughest of terms, i.e. non-subnetted hosts in 192.168.1.0/24, all 254 hosts must be in the same VLAN and it cannot be that 192.168.1.x (all odd numbers) be in VLAN 2 and 192.168.1.y (all even numbers) in VLAN 3.
Right?
Thanks a lot.
Kind regards.
PS: yes, I am learning, but some questions are not answer clear enough for me. Thanks.
Correct Answer by thotsaphon about 8 years 2 weeks ago
Hi Ben,
For switching between Vlans. You properly use L3 switch to accomplish that. You can use a router to do intervlan-routing as well.
It's not possible. You may think of this way. 192.168.1.0/25 - Vlan2 and 192.168.1.128/25 - vlan3
HTH,
Toshi
Overall Rating: 5 (1 ratings)
Correct Answer
thotsaphon Mon, 06/08/2009 - 02:19
  • Gold, 750 points or more
Hi Ben,
HTH,
Toshi
