Cisco AP521G on UC520
Jun 8th, 2009
How can i configure an Access Point Cisco AP521G on UC 520 with CCA 2.0? I see the AP, the smartports is configured on acces point on the fa/0/1 but they have no ip address, what is the problems?
final-reseaux Mon, 06/08/2009 - 07:55
I have resolved the problems but an other is coming. When i have no security on the ap, i can connect no problems but when i want to securit them with wpa-psk or wep i can't authetificate? What is my problems?
Steven Smith Tue, 06/09/2009 - 09:04
You might look at ASCII vs HEX keys.  CCA does ASCII, you should check to make sure that your are using ASCII on the clients.
Steven Smith Tue, 06/09/2009 - 13:02
The depends on the software being used to control the wireless card.  Usually there would be a button where you enter the WEP or WPA key that would say ASCII or HEX.
