ACS upgrade to above ( or 4.2)
Jun 8th, 2009
I have an acs requiring an upgrade. It has running. Can i directly upgrade it to 4.2 with the recovery dvd or should i first upgrade it to and then to the reimage.
If i have to upgrade to 1.24, how do i got about that ? Do I need to open a TAC or is it an upgrade on ?
ansalaza Mon, 06/08/2009 - 04:06
You can upgrade directly to ACS 4.2 with the recovery DVD, no need to upgrade to ACS and then to 4.2.
Remember to make a backup before the upgrade.
There is a feature that allows you to restore any ACS 4.1 backup into ACS 4.2.
"Before you begin any upgrade procedure, we recommend that you back up your existing data and configuration. When, upgrading do a re-image of ACS 4.2 and then restore the ACS 4.1 configuration."
ahmedchohan Sat, 06/13/2009 - 23:35
Agreed, but that feature says that the exception is on the . I have does that still hold correctly for the upgrade ?
ansalaza Mon, 06/15/2009 - 08:20
You should be able to restore the configuration using the option: "Restore from 4.1 backup file to ACS 4.2").
