VACL question - more then 1 filter same VLAN?
Jun 8th, 2009
Is it possible to have more then 1 vlan-filter applied to the same VLAN?
Here is our situation;
>> 2 separate capture devices on different ports
>> 1st capture port we want all traffic
>> 2nd capture port we want to filter some of the traffic
We have the VACL setup and working as expected with the one filter, but we don't see how we could have a separate filter setup for the same VLAN.
Can this be done?
If yes, could you point us at a working configuraiton?
Thank you
Giuseppe Larosa Wed, 06/10/2009 - 13:33
  • Hall of Fame,
    Founding Member
Hello Keith,
I think this is not possible.
you can have multiple destinations of a span session and you can configure a capture filter on second device.
Hope to help
Giuseppe
