Guide me for Subnet
Jun 8th, 2009
I am using 192.168.1.0/24 network for my one of the site
now i my all 254 host has been used.
i am out of ip address
can i use
192.168.0.0/23 subnet
so that my first host ip will be 192.168.0.1/23
pls advise me
may this is silly question but i hev some doubt
thotsaphon Mon, 06/08/2009 - 04:42
Jitendra,
There is no silly question here. (grin)
Yes, you can use 192.168.0.0/23.
Technically speaking, you may be concerned about a broadcast domain as well.
HTH,
Toshi
greg.washburn Mon, 06/08/2009 - 06:37
If you do this just remember you will need to change any each individual computer to get the correct subnet mask. If using dhcp server this task may be a little less time consuming as you can change it there and then reboot or release / renew each pc rather than statically change them.
