Failover on ASA by IP on different subnet?
John Blakley
I'll be configuring an ASA 5550 for a DR site. Is there a way that I can configure this 5550 to be a failover in case the primary in the main site goes down even though it's on a different subnet?
John
HTH, John *** Please rate all useful posts ***
Jon Marshall
John
If you mean failover as in active/standby scenario then no you can't because for that to work the firewalls need to have L2 adjacency.
Jon
5 Replies 5
Jon Marshall
John
Jon
Jon-
If they were in the same subnets could you? I have 10 gig between my datacenters. I think you can, my issue would be detecting what types of failover. Can you track for failover purposes? I can loose internet link, but the link stays up? Thanks for your help.
Jake
"If they were in the same subnets could you ?"
Yes you could although you would need to factor in the latency between the 2 sites and see if that would affect keepalive/state packets.
I don't believe the ASA support object tracking in the same way a router does.
Is your internet link terminated into a router then ?
Jon
The internet is at both sites with 7200s. I did see that the ASA can do ip sla tracking, but its only for default routes. Since these are going to be at different locations, I need to be able to track the inside route as well. Any guidance is appreciated.
