V-LAN
Jun 8th, 2009
Hi, I need to create three V-LANS configured on Subinterfaces of FW which will be connected with L2 Switch and same V-LANS I will create on L2 Swicth. Should the connection between Switch and FW be in Trunk mode or if its not be in Trunk mode then may i know why as all V-LAN traffic goes by Trunk mode as I assume. Pls clarify. Thanks
Jon Marshall Mon, 06/08/2009 - 06:14
Ray
Yes, the switchport that the ASA connects into should be configured as an 802.1q trunk.
Jon
ray_stone Mon, 06/08/2009 - 06:22
And what about the port of Cisco ASA FW, it should also be configured in Trunk mode.
