T1 Voice WIC Preferred ISDN PRI Specs
Jun 8th, 2009
Does anyone know which of the following parameters are the "default", "preferred" or available options as it relates to a T1-PRI interface on a UC500?
  • Number of Digits outpulsed: 4, 7, or 10
  • ISDN Version: NI-1, NI-2 or Custom
Marcos Hernandez Mon, 06/08/2009 - 07:17
  • Blue, 1500 points or more
Using CCA 2.0, the number of digits for outbound calls depend on the dialplan configuration. Using the embedded NA dial plan, you can do 7 and 10 digits.
Regarding the switch type, you can select "primary-ni"for National ISDN Switch types 1 and 2, but by default no ISDN configuration is there.
Hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
