QoS/Traffic Shaping to avoid Output Drops on ATM Interface
Jun 8th, 2009
I have an ATM on 2800 Series, configured as follows:
Router#sh run interface atM 0/1/0.1
Building configuration...
Current configuration : 290 bytes
interface ATM0/1/0.1 point-to-point
mtu 1500
bandwidth 1200
ip address 10.100.0.22 255.255.255.252
ip helper-address 192.168.101.3
no snmp trap link-status
pvc 8/35
vbr-rt 576 288 36
tx-ring-limit 4
oam-pvc manage
encapsulation aal5snap
service-policy output QoS
end
The output of the command show dsl interface ATM 0/1/0 is as follows:
Router#show dsl interface ATM 0/1/0
ATM0/1/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: ' ' 'TSTC'
Vendor Specific: 0xDBB0 0x0000
Vendor Country: 0x04 0xB5
Capacity Used: 29% 78%
Noise Margin: 15.5 dB 15.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 37.5 dB 21.5 dB
Defect Status: None None
Last Fail Code: Handshake or init message invalid or had bad CRC
Watchdog Counter: 0x05
Watchdog Resets: 2
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 9048 (0 spurious)
PHY Access Err: 0
Activations: 138
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: ASW_init_3_8_131.bin
Operation FW: ASW_R3_8_131.bin
FW Source: embedded
FW Version: 3.8.131
Interleave Fast Interleave Fast
Speed (kbps): 1504 0 608 0
Cells: 4977248 0 80677883 0
Reed-Solomon EC: 192 0 38 0
CRC Errors: 2 0 0 0
Header Errors: 2 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 5 4 6 8 9 9 A A A
010: A A A A A 9 9 9 9 9 8 7 6 5 0 0
020: 0 0 0 0 0 0 0 0 2 2 2 2 2 3 2 3
030: 3 3 3 3 3 3 3 3 3 3 3 2 3 2 3 3
040: 0 3 3 3 3 3 3 3 3 3 4 3 4 4 4 4
050: 3 2 2 4 4 5 5 5 5 2 5 5 5 4 4 4
060: 4 4 4 4 4 3 2 4 4 4 5 5 5 5 4 4
070: 4 4 4 4 4 4 4 4 4 3 2 2 4 4 4 4
080: 4 4 4 4 4 4 4 4 4 4 4 4 2 0 0 0
090: 0 3 3 3 4 4 4 4 4 4 4 4 4 3 3 3
0A0: 2 2 2 2 2 2 2 2 3 3 3 3 3 3 3 3
0B0: 3 2 2 2 0 0 0 0 0 0 0 2 2 2 2 2
0C0: 2 0 2 2 2 2 2 2 0 0 0 0 0 0 0 0
0D0: 0 2 2 2 2 2 2 2 2 2 2 0 0 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
Router#
The problem is that I continue to have an output drops on the interface:
Router#sh interfaces atM 0/1/0
ATM0/1/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 1200 Kbit, DLY 840 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4d06h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1473
Queueing strategy: Per VC Queueing
30 second input rate 8000 bits/sec, 4 packets/sec
30 second output rate 9000 bits/sec, 6 packets/sec
3846354 packets input, 602702599 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
4623694 packets output, 571626291 bytes, 0 underruns
Router#
How can I do? Do you have any suggestions? Maybe something wrong?
Thanks!
Giuseppe Larosa Mon, 06/08/2009 - 07:10
  • Hall of Fame,
    Founding Member
Hello Paolo,
use
sh policy-map int atm0/1/0 to see statistics of the service policy.
You may need to use hierchical QoS:
a parent service-policy doing shaping in single class class-default that invokes a child policy where you implement CBWFQ.
Hope to help
Giuseppe
Paolo Bratti Mon, 06/08/2009 - 08:07
in my runnig-config I have something like that:
class-map match-any Voice
match protocol rtp
match protocol skinny
match protocol h323
class-map match-any Dati-MCritical
match protocol citrix
policy-map QoS
class Voice
priority percent 50
class Dati-MCritical
priority percent 10
class class-default
fair-queue
and the output of the command sh policy-map int atm0/1/0.1 is:
Router#sh policy-map int atm0/1/0.1
ATM0/1/0.1: VC 8/35 -
Service-policy output: QoS
Class-map: Voice (match-any)
456492 packets, 36103289 bytes
30 second offered rate 28000 bps, drop rate 0 bps
Match: protocol rtp
418498 packets, 33557578 bytes
30 second rate 28000 bps
Match: protocol skinny
35541 packets, 2259419 bytes
30 second rate 0 bps
Match: protocol h323
2453 packets, 286292 bytes
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 50 (%)
Bandwidth 144 (kbps) Burst 3600 (Bytes)
(pkts matched/bytes matched) 56433/4413302
(total drops/bytes drops) 191/39124
Class-map: Dati-MCritical (match-any)
127545 packets, 8654122 bytes
30 second offered rate 5000 bps, drop rate 0 bps
Match: protocol citrix
30 second rate 5000 bps
Queueing
Strict Priority
Bandwidth 10 (%)
Bandwidth 28 (kbps) Burst 700 (Bytes)
(pkts matched/bytes matched) 4593/393559
(total drops/bytes drops) 473/106266
Class-map: class-default (match-any)
1023857 packets, 171914476 bytes
30 second offered rate 8000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 32
(total queued/total drops/no-buffer drops) 0/714/0
Router#
Giuseppe Larosa Mon, 06/08/2009 - 08:43
  • Hall of Fame,
    Founding Member
Hello Paolo,
you have one level of QoS with a CBWFQ + LLQ for voice (priority)
One important note is the following:
the pvc 8/35 is configured for
vbr-rt 576 288 36
tx-ring-limit 4
the physical atm interface has BW 1200 kbps.
As you can see a priority percent 50 is seen as 144 kbps that is 50% of 288 kbps the second parameter in vbr-rt command
The sh policy-map int atm0/1/0.1 shows that all classes have experienced drops.
if the PVC settings are correct and you want to be sure to respect these parameters you need a parent policy like
policy-map shape_all_at_288
class class-default
shape average 288
service-policy QoS
and you apply to atm0/1/0.1
int atm0/1/0.1
service-policy output shape_all_at_288
Hope to help
Giuseppe
paolo bevilacqua Mon, 06/08/2009 - 22:55
  • Hall of Fame,
    Founding Member
Why?
A PVC with SCR should not need L3 shaping or nested policies.
I'm not sure why there are drops in the PQ, perhaps there were a lot of calls at a given time.
Giuseppe Larosa Tue, 06/09/2009 - 02:07
  • Hall of Fame,
    Founding Member
Hello Paolo,
I agree with you I was concerned with the fact that there are drops in all classes.
So you think that it can be a problem of call admission control that allows too many concurrent voice calls?
Best Regards
Giuseppe
paolo bevilacqua Tue, 06/09/2009 - 04:01
  • Hall of Fame,
    Founding Member
Really I'm not sure, one should see things running to understand better.
Paolo Bratti Thu, 06/11/2009 - 23:21
I have read this guide http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800d76b5.shtml
I think, that QoS shaping is not supported in my WIC-1ADSL on Cisco 2801; infact when I try to apply my parent policy-map Prova on the VC I don't show it in my running-config.
match protocol rtp
match protocol h323
policy-map QoS
class Voice
priority percent 50
priority percent 10
class class-default
fair-queue
policy-map Prova
class class-default
shape average 576000
service-policy QoS
Thanks!
