How to set speed and duplex for APs
Jun 8th, 2009
I'm using two 4402 running the following versions:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 5.2.157.0
RTOS Version..................................... 5.2.157.0
Bootloader Version............................... 4.2.112.0
Emergency Image Version.......................... 5.2.157.0
Build Type....................................... DATA + WPS
Where can I set the speed/duplex mode for the APs?
In earlier versiones there was a "config ap ethernet"-command.
Any ideas?
Regards Dirk
tsennett Mon, 06/08/2009 - 12:03
This works in 5.0.148.2
config AP ethernet duplex (x) speed (x) (AP NAME)
Dirk Woellhaf Mon, 06/08/2009 - 23:58
Thanks for the reply,
but I don't want to downgrade.
Does anyone know if thess commands are back in the upcoming versions?
regards
Vinay Saini Tue, 06/09/2009 - 03:10
  • Cisco Employee,
Yes ,
These commands are there new versions.
Haven't checked in the version you mentioned,But should not have got removed.
Vinay
Dirk Woellhaf Tue, 06/09/2009 - 03:30
Good to know.
Any suggestion when Version 6.x will be available for 440x series?
Regards Dirk
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
