IP Plus Feature Set for a Cisco 3560E-48PD
Jun 8th, 2009
I found that to utilize the TTCP test tool (which tests the throughput between 2 devices), it requires the IOS feature set IP Plus. Can anyone help me to find this IOS version for the Cisco 3560E-48PD? Thanks in advance.
Edison Ortiz Mon, 06/08/2009 - 07:52
The universal code provides all features not found in IP Base code. To open the extra features, you need to contact your Cisco reseller and purchase a key. With the key, you can upgrade to IP Plus, IP Services, Advanced IP Services, etc.
HTH,
__
Edison.
