UC500 + SR520 VPN Problem
I had a VPN tunnel working with a UC500 and SR520.  I installed the SR520 at a customer site.  I pulled another SR520 out of the box and restored the config from the previous SR520.  The VPN tunnel will not work.  I have attached the show run from both boxes and some debug info.
The tunnel is just for a remote phone but there may be a need for data at some point.
Marcos Hernandez Thu, 06/11/2009 - 05:58
  • Blue, 1500 points or more
Apologies for the silence. I have been exchanging quite a few emails with the SR520 TME on how to better document VPN scenarios that make use of this router, all triggered by this post. I have also asked some folks to take a look at your issues. I will take a look myself.
Marcos
Thanks for your time.
I had the UC500 to SR520 VPN working like a champ.  I made documents for it.  For some reason, this just stopped working.
When I run the crypto debug commands (debug crypto ipsec, debug crypto isakmp, debug crypto engine), it doesn't even look the VPN tunnel is trying to negotiate.  I only get "crypto_engine: Generate public/private keypair" on the SR520.  I set the lifetime of the VPN to 3 minutes for troubleshooting so I get that message every 3 minutes.
Steven Smith Thu, 06/11/2009 - 14:40
  • Gold, 750 points or more
You might need to initiate traffic to get the VPN tunnel up.  By that, I mean source traffic from a device behind the SR520 and try to connect to the UC520.  After that, run your debugs.
David Trad Thu, 06/11/2009 - 15:36
  • Cisco Designated VIP,
    2013 Small Business
I am by no means and expert on VPN's in fact i break them more often then i actualy create/fix them, but can i throw a couple of suggestions/thoughts into the works here.
  1. Has anything changed with your ISP of late?
  2. Have you moved up or down in your plans which might have changed something at your ISP level?
  3. Which device sees two-way traffic and which one doesnt?
  4. Does it connect up at all and then just drops out?
  5. Be it dramatic and all but have you looked at reloading both the SR520 and the UC520? ( I know not ideal but it is a thought)
  6. Did you use an older version of CCA to create the configs for both devices and then upgraded to another version of CCA? (Moving from 1.8-1.9 didnt really create much of a problem, but moving from 1.8 - 2.0 has had some unwanted consequences) just by opening up version 2.0 and connecting to the device can alter the config, it is supposed to ask you if you want it altered but we have seen it make changes without asking.
These are just things i would check, they normaly dont lead anywhere cause when problems with VPN occur with me, they occur soley on the purpose of giving me headaches and hard times.
Hope these questions trigger a thought and you can resolve your problem quick, i know i am often wishing someone would shoot me when the problem doesnt go away.
Cheers,
David.
From the debug info, there is traffic in the pkts encaps section for the 10.1.1.0 network but nothing for pkts decaps on the SR520.  On the UC520 side, it is the opposite.  There is traffic in pkts decaps but nothing for pkts decaps.  From this information, it looks like traffic is only going one way.
John Platts Tue, 06/16/2009 - 09:21
  • Silver, 250 points or more
Here are the fragments of your UC520 config containing incorrect values (incorrect values are in red):
crypto isakmp key D6uKu4ap address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode transport
crypto map CISCO 10 ipsec-isakmp
set peer ciscovpntest.gotdns.com dynamic
set transform-set ESP-3DES-SHA
set pfs group2
match address 105
interface FastEthernet0/0
ip address 98.100.195.78 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map CISCO
access-list 105 permit ip 10.12.200.0 0.0.0.255 192.168.75.0 0.0.0.255
access-list 105 permit ip 10.1.1.0 0.0.0.255 192.168.75.0 0.0.0.255
Here are the commands for removing the incorrect configuration on the UC520:
no crypto map CISCO
no crypto map CISCO 10
no crypto isakmp key D6uKu4ap 0.0.0.0 0.0.0.0
no mode transport
Here is the corrected UC520 configuration:
crypto keyring HMIVPN-Keyring
pre-shared-key address 0.0.0.0 0.0.0.0 D6uKu4ap
crypto isakmp profile HMIVPN-KeyProfile
match address 0.0.0.0
crypto ipsec profile HMIVPN-Tunnel
set isakmp-profile HMIVPN-KeyProfile
set pfs group2
interface Tunnel0
ip unnumbered Vlan1
tunnel source FastEthernet0/0
tunnel destination ciscovpntest.gotdns.com
tunnel mode ipsec ipv4
tunnel protection ipsec profile HMIVPN-Tunnel
! Add route to SR520 via VPN tunnel
ip route 192.168.75.0 255.255.255.0 Tunnel0
Here are the fragments of you SR520 configuration containing incorrect values (incorrect values are in red):
crypto isakmp key D6uKu4ap address 98.100.195.78
mode transport
set peer 98.100.195.78
set pfs group2
match address 105
interface FastEthernet4
ip address 192.168.1.200 255.255.255.0
duplex auto
speed auto
crypto map CISCO
access-list 105 permit ip 192.168.75.0 0.0.0.255 10.12.200.0 0.0.0.255
access-list 105 permit ip 192.168.75.0 0.0.0.255 10.1.1.0 0.0.0.255
Here are the commands for removing the incorrect configuration on the SR520:
no crypto map CISCO
no crypto isakmp key D6uKu4ap address 98.100.195.78
no mode transport
Here is the corrected SR520 configuration:
pre-shared-key address 98.100.195.78 D6uKu4ap
match address 98.100.195.78 255.255.255.255
set pfs group2
interface Tunnel0
ip unnumbered Vlan1
tunnel source FastEthernet4
tunnel destination 98.100.195.78
! Add routes to UC520 LAN and CUE subnets via VPN tunnel
! I have added the CUE subnet since some of the CUE features require this routing entry
ip route 10.12.200.0 255.255.255.0 Tunnel0
ip route 10.1.1.0 255.255.255.0 Tunnel0
ip route 10.1.10.0 255.255.255.252 Tunnel0
Thanks for the input.  VPN tunnels have been a struggle.  I will give it a shot.
When I tried the commands on the UC500, I got the following results:
UC520(config)#crypto keyring HMIVPN-Keyring
UC520(conf-keyring)#pre-shared-key address 0.0.0.0 0.0.0.0 D6uKu4ap                                                           ^
% Invalid input detected at '^' marker.
It is pointing to the D in the key.
UC520(conf-keyring)#!
UC520(conf-keyring)#crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
UC520(cfg-crypto-trans)#!
UC520(cfg-crypto-trans)#crypto isakmp profile HMIVPN-KeyProfile% A profile is deemed incomplete until it has match identity statements
UC520(conf-isa-prof)#keyring HMIVPN-Keyring
UC520(conf-isa-prof)#match address 0.0.0.0
                           ^% Invalid input detected at '^' marker.
It is pointing to the a in address.
UC520(conf-isa-prof)#!
UC520(conf-isa-prof)#crypto ipsec profile HMIVPN-Tunnel
UC520(ipsec-profile)#set transform-set ESP-3DES-SHA
UC520(ipsec-profile)#set isakmp-profile HMIVPN-KeyProfile
UC520(ipsec-profile)#set pfs group2UC520(ipsec-profile)#!
UC520(ipsec-profile)#interface Tunnel0UC520(config-if)#ip unnumbered Vlan1
UC520(config-if)#tunnel source FastEthernet0/0
UC520(config-if)#tunnel destination ciscovpntest.gotdns.comTranslating "ciscovpntest.gotdns.com"...domain server (65.24.0.169) [OK]
UC520(config-if)#tunnel mode ipsec ipv4
UC520(config-if)#tunnel protection ipsec profile HMIVPN-Tunnel
UC520(config-if)#exit
Thanks again.
John Platts Tue, 06/16/2009 - 11:57
I had made an error. It should be pre-shared-key address 0.0.0.0 0.0.0.0 key D6uKu4ap instead of pre-shared-key address 0.0.0.0 0.0.0.0 D6uKu4ap.
John Platts Tue, 06/16/2009 - 12:02
Here is the corrected UC520 configuration (with some mistakes fixed):
  match identity address 0.0.0.0
set pfs group2
interface Tunnel0
ip unnumbered Vlan1
John Platts Tue, 06/16/2009 - 12:06
Here is the corrected SR520 Configuraiton (with mistakes fixed):
pre-shared-key address 98.100.195.78 key D6uKu4ap
match identity address 98.100.195.78 255.255.255.255
set pfs group2
interface Tunnel0
ip unnumbered Vlan1
Thanks.  It was actually a good exercise for me to use the ? help.  I always forget about that.
One other quick question.  When I put in this command: tunnel destination ciscovpntest.gotdns.com...it translates it to the IP address in the config.  Will it still work if the IP changes since it is dynamic?
The tunnel came up right away.  The phone registered once I entered it into the config manually.
The only question remaining is the dynamic IP issue.  Is there a command to use the host name instead of the IP for tunnel destination?  Since it converts the hostname to IP in the config, it looks like it would not update.
I had a 'normal' static/dynamic crypto map configured, but the remote phone (524) didn't want to work. Everything else was fine. I changed from the crypto map over to the tunnel configuration, and the phone fired right up. The only issue is, the dynamic ip in the 'tunnel destination' statement.
This is the first, and probably last time I use these SR520s until they put DMVPN in them. Until then, back to 871s I guess. Then if we could just get dynamic routing in the UC520 we'd be all set.
