Software Conference Bridge
Jun 8th, 2009
hi all,
I have CCM 6.1 integrated with Voice Gateway via H.323, i am able to make conference between extensions but i m not able to make conference between PSTN numbers ... my Codec in Region is G.711 ... on Voice Gateway i configured nothing related to Conference ... do i need to do some configure on VG if yes then what do i need to configure ????
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 06/08/2009 - 10:03
SW CFB only supports G711
H323 by default uses G729 in VoIP dial-peers unless configured to use G711.
Check that.
java
if this helps, please rate
