Ciscoworks upgrade
Jun 8th, 2009
  • Purple, 4500 points or more
I have never tried this . How does Ciscoworks handle a upgrade of say a 4500 with dual supervisors in it ? Does it some how specify which supervisor you want to put the image on ?
Overall Rating: 4 (1 ratings)
yjdabear Mon, 06/08/2009 - 10:28
  • Gold, 750 points or more
If it's anything like the cat6500, it depends on how RME SWIM's 4500 device support pkg was built, to use ENTITY-MIB or CISCO-STACK-MIB. But the word from CiscoWorks DEV I got was, for dual-SUP devices, only the Primary SUP should have a checked checkbox in the SWIM GUI. The Secondary SUP should be grayed out. If both SUPs are checkable, it's actually incorrect behavior due to the MIB used and/or faulty implementation, in which case the SWIM job would tell you the SW Upgrade "failed" even though it's successful (to the Primary SUP only), because (per Cisco DEV) SWIM is never designed to push code to both SUPs. The code version sync between SUPs is supposed to be handled by the OS itself.
glen.grant Tue, 06/09/2009 - 15:29
So it will download the code to one supervisor and that automatically gets pushed to the 2nd Sup ?
yjdabear Tue, 06/09/2009 - 15:50
Yes, for exmaple if HA is on and versioning is off according to "show system highavailability":
Highavailability: enabled
Highavailability versioning: disabled
Highavailability Operational-status: ON
