PIX 515e
Jun 8th, 2009
Hi there,
I have at my lab a Cisco PIX 515e (failover) and it boot every 24 hours. The strange thing is every time it boots (automatic or forced one) it misses the remote access via ssh, and I have to go to the console and re-enter the "cry key gen rsa" command. Does anyone have any idea? Thanks in Advance.
Jonas
Jon Marshall Mon, 06/08/2009 - 13:12
Jonas
After you generate the key are you then using this command -
pix# ca save all
this command writes the keys to persistent memory on the pix so it should be available after a reload.
Jon
j.conceicao Tue, 06/09/2009 - 05:01
Hi Jon,
Thanks for your help.
This command does exist anymore. I just use the write command, but it doesn't save the generated key at all. Anything else that I could do? Thanks again.
MaxiFire(config)# ca save all
WARNING: the 'ca' command syntax has been deprecated
CA root certificates, device certificates, and RSA key pairs are now saved by issuing a 'write mem'
Jonas
srue Tue, 06/09/2009 - 06:15
if it only has a failover license but it not actually a memeber of a failover pair, it probably won't be able to save these locally.
j.conceicao Tue, 06/09/2009 - 07:07
Hi Srue,
Hmmm, why only the ca key? All the configuration remains...
Jonas
