Problems with a Switch Catalyst 3560
Jun 8th, 2009
Hi.
We have a Switch Catalyst 3560 as the hub of our net One of its ports is connected to a Gateway, that we don't administer.
When we connect a new computer to the switch, there is times that you can connect to this equipment from outside until that you make a ping since the new equipment to any address out of the net.
Any can help me?
Thanks.
Kinai.
benson.low Thu, 06/11/2009 - 18:38
Check the machine IP's, netmask and gateway and make sure it is inline with the gateways.
Check the switch counters and see any errors that culd arise.
Beno
