CUE mailbox no. license upgrade
Jun 8th, 2009
  • Silver, 250 points or more
Kindly help for these queries:
1. This license is downloadable from Cisco
So if we consider i have 100 hour as a full capacity
and the current license is 25 mailboxes
so every mailbox will have 4-hours
So If i need to increase the number of mailboxes, i can download the license file for 50 users as for example
then every mailbox will have 2 hours automatically
Is this will be for free without any purchase order ?
2. I'll upgrade to cue 7, so I found all doc talked about the packages without mentioning the license file for the new version
I guess i must download the new license file for the new code 7.0.3 to be compatible with the new downloaded files, or I can upgrade with no care about the license file ? and then I'll have all files [main pkg,installer,lang pak..] in version 7 but the license file will still version 3.
3. Finally is there any new features in cue 7 than earlier releases ?
Thanks & Best Regards
Hytham Hadad
Overall Rating: 2.7 (3 ratings)
Paolo Bevilacqua Mon, 06/08/2009 - 13:58
  • Hall of Fame,
    Founding Member
1. it is not free. Legally, you've to order the license.
2. always use license files for the specific CUE version you have.
3. refer to documentation. A ist of new features is in there.
Hythim Ali El Hadad Wed, 06/10/2009 - 07:13
Thanks for your reply
Could you please clarify point 1 and 3 in more details
1. The cucm 7 isn't allowed you to add more and more phones without existing license,
So in my case what will prevent the cue from having the new mailbox number after downloading the new license file ?
for point 3. I need to know the new features which will take the customer attention and force him for the upgrade
Finally,If i download cue 7 files,Will the new version license file need a new license ?
Thanks for your care
Hytham Hadad
Hythim Ali El Hadad Tue, 06/09/2009 - 00:40
Hytham Hadad
Paolo Bevilacqua Tue, 06/09/2009 - 04:06
  • Hall of Fame,
    Founding Member
Assuming it's you that have low rated my 100% correct answer above, that is wrongly done and you should correct your attitude.
Fairness come before knowledge, good luck.
Hythim Ali El Hadad Wed, 06/10/2009 - 07:15
From the day I have visited this forum
I was happy alot from the replies of Rob Huffman, it is really helpful
Although some times I was having no poblems, I come here to browse his answers
So the 3-answers above is not satisfing what i was looking for specially the 3rd point
So i see it give some help, not very helpfull from my view
And I think this forum is to share knowledge, not to be sad for not rating
thanks for your kind reply
Paolo Bevilacqua Wed, 06/10/2009 - 12:05
  • Hall of Fame,
    Founding Member
I'm not sad for rating, as I have more than enough of it.
It is you that are misusing the system and make a fool of yourself in continuing to do so.
Beside that, the complete answer to your questions is in my first reply, if you are unable to search and read documentation, that is not my fault.
Rob Huffman Wed, 06/10/2009 - 12:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Paolo
+5 :)
Huff
Paolo Bevilacqua Wed, 06/10/2009 - 12:39
  • Hall of Fame,
    Founding Member
Thanks Rob, but I feel a bit uneasy now, because I never intended to be rated for an answer I had to give without relation to technical matters.
I can only try to improve my contribution with the explicit link to the new CUE features that the OP was asking for:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/rel_notes/rel_notes.html#wp225607
Rob Huffman Wed, 06/10/2009 - 12:49
  • Hall of Fame,
    Founding Member
Hey Paolo,
No worries, I meant to rate your excellent first answer my friend! As usual, my dyslexic skills have missed the mark. But the intent is still the same :)
Cheers!
Huff
