HUM Portal viewing by customer / domain?
Jun 8th, 2009
Hi, I would like to know how I can use HUM and it's display and filter for customer views? If this is even possible as well when it might be available if not.
I have one system, multiple customers and only one HUM portal which shows all devices.
Joe Clarke Mon, 06/08/2009 - 21:57
In order to do any kind of device restriction, you need to enable ACS integration. From there, you will only be able to create pollers for devices to which your user has access in ACS. Each user is then capable of creating their own private portal for those pollers.
rtuttle Thu, 06/11/2009 - 10:02
Thanks Joe, lot of work there though. Would rather do by groups.
