VG224 Fax Passthrough not recognizing digits dialed
Jun 8th, 2009
We are switching from fax relay to fax passthrough on our VG224 fax gateway, however once I make the switch the VG224 stops recognizing dialed digits. When I try to dial a number from a fax machine I get the dial tone and hear the tones for the digits dialed, but after about 5 seconds I get another dial tone and then the call times out. Any thoughts?
This is connected via MGCP to our Callmanager 7 cluster.
I also after making this change cannot receive any inbound calls (just get a busy signal) If I run a debug voip ccapi inout on the VG224 I get the following:
VG224-1#
Jun 8 22:32:06.894: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x630D561C, Interface Type=6, Destination=, Mode=0x9,
Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 8 22:32:06.894: //86/082A60268091/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jun 8 22:32:06.894: //86/082A60268091/CCAPI/ccCallSetContext:
Context=0x633EF9A0
Jun 8 22:32:06.898: //86/082A60268091/CCAPI/cc_api_call_proceeding:
Interface=0x630D561C, Progress Indication=NULL(0)
Jun 8 22:32:06.898: //86/082A60268091/CCAPI/ccCallModify:
Nominator=0x4000000, Params=0x633373A0, Call Id=86
Jun 8 22:32:06.902: //86/082A60268091/CCAPI/ccCallFeature:
Feature Type=23, Call Id=86
Jun 8 22:32:06.902: //86/082A60268091/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x630D561C, Call Id=86
Jun 8 22:32:06.902: //86/082A60268091/CCAPI/cc_api_call_alert:
Interface=0x630D561C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Jun 8 22:32:06.906: //86/082A60268091/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
Jun 8 22:32:06.906: //86/082A60268091/CCAPI/ccCallFeature:
Feature Type=33, Call Id=86
Jun 8 22:32:06.906: //86/082A60268091/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=86
Jun 8 22:32:06.906: //86/082A60268091/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jun 8 22:32:06.906: //86/082A60268091/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Jun 8 22:32:06.914: //86/082A60268091/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x630D561C, Tag=0x0, Call Id=86,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
VG224-1#
VG224-1#
Nicholas Matthews Mon, 06/08/2009 - 17:25
I can't tell what the problem is from the debugs/description.
If you can post 'show run' and then:
debug mgcp packet
I can probably tell you what's going on.
My best guess is this:
You aren't matching the right incoming dial peer. 'debug voip dial-peer' and your incoming dial peer should have the port and 'service mgcpapp' on it.
Or, you just don't have the dial peer with service mgcp app on it.
Make sure that 'show mgcp endpoint' shows the port you're working with.
-nick
NPT_2 Mon, 06/08/2009 - 18:11
I'll see about posting the config and debugs when I can.
My first thought was the dial peer's were not being matched, but I can make calls if I use T.38 fax relay, but if I switch to fax passthrough (without making any other changes) I lose the digit recognition.
I'm switching from relay to passthrough to avoid some compatibility issues I have been running into with certain fax machines.
NPT_2 Tue, 06/09/2009 - 07:32
Here is the VG224 Configuration, let me know if you see anything out of the ordinary.
VG224-1#show run
Building configuration...
Current configuration : 3198 bytes
! Last configuration change at 07:20:17 PST Tue Jun 9 2009
! NVRAM config last updated at 07:20:32 PST Tue Jun 9 2009
version 12.4
no service pad
service timestamps log datetime localtime
service password-encryption
hostname VG224-1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock timezone PST -8
ip subnet-zero
ip domain name ***
ip name-server ****
ip name-server ****
no ip dhcp use vrf connected
voice-card 0
interface FastEthernet0/0
ip address ************
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway ***********
ip classless
ip route 0.0.0.0 0.0.0.0 ***********
ip http server
snmp-server community *********
snmp-server community**********
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager redundant-host ***********
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server **************
ccm-manager config
mgcp
mgcp call-agent ********* 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
mgcp default-package fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 12000
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 99920 pots
service mgcpapp
port 2/0
dial-peer voice 999223 pots
service mgcpapp
port 2/23
dial-peer voice 99921 pots
service mgcpapp
port 2/1
dial-peer voice 99922 pots
service mgcpapp
port 2/2
dial-peer voice 99923 pots
service mgcpapp
port 2/3
dial-peer voice 99924 pots
service mgcpapp
port 2/4
dial-peer voice 99925 pots
service mgcpapp
port 2/5
dial-peer voice 99926 pots
service mgcpapp
port 2/6
dial-peer voice 99927 pots
service mgcpapp
port 2/7
dial-peer voice 99928 pots
service mgcpapp
port 2/8
dial-peer voice 99929 pots
service mgcpapp
port 2/9
dial-peer voice 999210 pots
service mgcpapp
port 2/10
dial-peer voice 999211 pots
service mgcpapp
port 2/11
dial-peer voice 999212 pots
service mgcpapp
port 2/12
dial-peer voice 999213 pots
service mgcpapp
port 2/13
dial-peer voice 999214 pots
service mgcpapp
port 2/14
dial-peer voice 999215 pots
service mgcpapp
port 2/15
line con 0
line aux 0
line vty 0 4
password 7 *************
login
ntp clock-period 17179886
ntp server ************
end
VG224-1#
NPT_2 Tue, 06/09/2009 - 08:01
The dial peer debug comes back as follows when I try to make a call from a fax machine just gives me dial tone after dialtone:
VG224-1#
Jun 9 15:57:38.876: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x630D561C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=99920
Jun 9 15:57:38.876: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:[email protected]
VG224-1#
NPT_2 Tue, 06/09/2009 - 09:37
It looks like I have figured it out. I determined that my VG224 was running really old IOS 12.4(2)T5 IOS I updated to 12.4(24)T and everything seems to be working now.
