How to Run Queries, Informix CCM 6
Jun 8th, 2009
Hi All,
We use to use SQL to run advanced queries and reports on our cdr database for particular extensions. We recently upgraded to ccm6 and don't really have any idea how to connect to and query the new database on the Linux OS. Do you have any suggestions, and do I have to purchase software in order to do this?
Overall Rating: 5 (1 ratings)
sammysammys Tue, 06/09/2009 - 06:44
So I would log into the CLI, and use the sql command? Could I output the results to a file or would it just show on the screen? Ideally I want it like sql queries on the sql db. Where I can select all calls to or from a particular extension and then send the reports to a csv...
Thanks for the help.
Jaime Valencia Tue, 06/09/2009 - 06:58
  • Cisco Employee,
  • Hall of Fame,
    2011
It only shows in the screen but you can use something like putty to capture the output and then process it however you want
java
if this helps, please rate
sammysammys Tue, 06/09/2009 - 07:06
Ok, that makes sense. Sorry, one more question.
In SQL I would enter" Select * from cdr where caller_number = xxxx"
Is the database the same name, and are the fields all the same as well? My example isn't 100% accurate :).
Jaime Valencia Tue, 06/09/2009 - 07:14
  • Cisco Employee,
  • Hall of Fame,
    2011
Example
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
Most of the fields remain the same
java
sammysammys Tue, 06/09/2009 - 07:19
Great, thank you.
I have another question though. Are there any free or not free third party reporting tools that people use to run these reports?
