Getting CUCM export files through ftp
Jun 8th, 2009
I have to integrate a directory into a CDR analyser 3rd party application. Having no Active Directory, I have to get every day the CUCM end-users database and format it for import into the application. I have scheduled an export via Bulk but I am looking for the best way to get the file. FTP ? SFTP ? AXL ?
Overall Rating: 5 (1 ratings)
htluo Tue, 06/09/2009 - 05:13
  • Red, 2250 points or more
What kind of data are you trying to get?
If you tried to get CDR, you should go to "Unified Serviceability > Tools > CDR Management". You may use SFTP or FTP.
If you tried to get end user database, that can only be done by AXL.
Michael
http://htluo.blogspot.com
guy.richard Tue, 06/09/2009 - 05:31
I want to get the User Export File generated by BAT. (The CDR are pushed by SFTP as usual)
Guy
Yorick Petey Wed, 10/20/2010 - 09:47
Hi Guy,
Did you find a solution to your request?
I am looking for the same thing: how to retrieve BAT generated files (using ftp or sftp for instance).
Thank you for your feedback.
Yorick
Yorick Petey Wed, 10/20/2010 - 22:21
It's too bad
We can retrieve files from activelogs, audit, install... from CLI. I would be more than happy to do the same with BAT files. I will look to export something using AXL.
Thanks for your feedback Guy.
