IOS C4507R (12.2.25-EWA11) serious software issue
Jun 9th, 2009
i found message in IOS software download
that IOS cat4000-i9k91s-mz.122-25.EWA11 found serious issue?
What IOS recommendation to replacement that IOS ?
Currently i'm using cat4000-i9k91s-mz.122-25.EWA11 in C4507R.
Lian
upgrade
Giuseppe Larosa Tue, 06/09/2009 - 04:01
Hello Lian,
the message is a disclaimer:
Cisco advices you the image is affected by a problem.
The problem is related to L2TP.
Other problems apply to OSPF or other L3 features.
If you are using the device as a L2 switch only actually none of these issues is of interest for you.
One is about SSH, again if you don't use SSH this is not a problem.
A suggestion for a later release can be done but a sh module would be needed to see what supervisor is installed.
However, the advice says that release 12.2(25)EWA12 is not affected
So I would try to download 12.2(25)EWA12.
Hope to help
Giuseppe
glen.grant Tue, 06/09/2009 - 11:39
You might want to move to the SG train as the EWA train is eol in November of this year.
edgar_pascal Tue, 06/09/2009 - 15:48
Hi Giuseppe,
thanks for the help i'm waiting for the EWA12.
Hi Glent,
what type of IOS SG train recommendation ?
Lian
here is my sh module C4507R:
C4507R#sh module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE11485C73
2 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE11485KE3
3 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE114749UR
4 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE11474D7L
5 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE11474GQS
6 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1235T5IK
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1237UUM6
M MAC addresses Hw Fw Sw Status
1 001e.4aea.0d00 to 001e.4aea.0d01 4.5 12.2(31r)SGA 12.2(25)EWA11, Ok
2 001e.4aea.0d02 to 001e.4aea.0d03 4.5 12.2(31r)SGA 12.2(25)EWA11 Ok
3 001e.7a2f.4d60 to 001e.7a2f.4d8f 2.4 Ok
4 001e.13cf.b160 to 001e.13cf.b18f 2.4 Ok
5 001e.4af4.5010 to 001e.4af4.503f 2.4 Ok
6 0023.0460.6200 to 0023.0460.622f 2.5 Ok
7 0023.33a1.55e0 to 0023.33a1.560f 2.5 Ok
Mod Redundancy role Redundancy mode Redundancy status
1 Standby Supervisor SSO Standby hot
2 Active Supervisor SSO Active
