how to remoce clock rate
Jun 9th, 2009
I have 2851 router with this IOS VERSION ((C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T1, ) and the clock rate 2000000 is on the serial interface by default,im try to remove it but it's not going,i dit no clock rate and no clock rate 2000000 on the interface but it is still there.
Giuseppe Larosa Tue, 06/09/2009 - 01:50
  • Hall of Fame,
    Founding Member
Hello Selome,
what to do depends on your target:
if you want the serial interface to accept a clock from line use
clock source line
if you want to configure a different rate
use
clock rate
Hope to help
Giuseppe
SELOMECIS Tue, 06/09/2009 - 02:01
my problem i want to remove it on the inteface,i dont wanna see any clock rate on the interface at all.
paolo bevilacqua Tue, 06/09/2009 - 04:02
  • Hall of Fame,
    Founding Member
Please send show controller for the interface in question.
Danilo Dy Tue, 06/09/2009 - 04:11
  • Blue, 1500 points or more
Try plugging the DTE cable on that router port and CSU (power on). It may go away.
