Second CUCM directory - mobile phones
Jun 9th, 2009
Cucm version 7.x. Client will be syncing with AD. They'll be using the cucm corporate directory for internal user lookups and dialing but they would also like to be able to search for users mobile phones within ad also. Was thinking of using the cisco sdk localizeddirectory for this and creating a new service called "mobile phone directory" which would also sync with their ad and do lookups via the mobile field.
Anyone know of another way of doing this without investing in extra hardware and software?
Jaime Valencia Tue, 06/09/2009 - 15:01
Unfortunately since now you can't access the tomcat files or the corporate directory script in linux appliances, there is no way to add or customize directories without a separate web server and developing your own directories scripts
if this helps, please rate
