Ciscoworks LMS 3.0.1 virtualization
Answered Question
Jun 9th, 2009
The server will be virtualized with the same features:
RAM: 4Gb
Processor: Intel Xeon 3.2 Ghz
HD: 140 Gb
I need to know if no problem with this kind of implementation.
Best regards,
thanks very much!
Correct Answer by Marvin Rhoads about 7 years 11 months ago
Virtualized OS support was not introduced until LMS 3.1. See http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/install/guide/prereq.html#wp1099303 for details.
Prior to LMS 3.1, you were limited to Windows Server Terminal Server installations for a "virtual" server.
If you are going to upgrade your LMS, also note that the latest release is LMS 3.2. Its relevant release notes section is here: http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1103497
LMS 3.2 added Hyper-V in addition to VMWare as a supported virtualization environment.
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Tue, 06/09/2009 - 05:00
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
