RSPAN: VoIP Traffic
Answered Question
Jun 9th, 2009
RSPAN
Customer has bought voice recorder software, and would like to capture.
viop traffic from vlan 10 and vlan 20
Please see attachment.
Q. How do I configure Rspan on the edge and core switches to cature the voice traffic.
Q. Will the voice recored server host port be a trunk port.
Please advise,
Colm
Correct Answer by iyde about 7 years 11 months ago
Q. How do I configure RSPAN on the edge and core switches to capture the voice traffic.
A: In the Edge switches you configure a SPAN session with VLAN 10 or VLAN 20, respectively, as the source, and a RSPAN VLAN as destination.
Example:
vlan xxx
name RSPAN_VLAN
remote-span
exit
monitor session 1 source interface vlan10|vlan20
monitor session 1 destination remote vlan xxx
In the core you configure the RSPAN VLAN as source and the physical interface to which the Voice Recorder is attached as the destination. Example:
vlan xxx
name RSPAN_VLAN
remote-span
exit
monitor session 1 source remote vlan xxx
monitor session 1 destination interface gig1/1
Make sure that VLANxxx is allowed on the trunk between edge switches and core switch.
Read more about SPAN and RSPAN here: http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swspan.html
A: No. The port will be a SPAN destination port. See http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swspan.html#wp1036749 for details.
HTH.
Ingolf
Overall Rating: 5 (1 ratings)
Correct Answer
iyde Tue, 06/09/2009 - 08:00
  • Silver, 250 points or more
Example:
vlan xxx
name RSPAN_VLAN
remote-span
exit
vlan xxx
name RSPAN_VLAN
remote-span
exit
HTH.
Ingolf
