Maximum VPN Sessions through ASA 5510 firewall
Jun 9th, 2009
In our Organisation ASA 5510 firewall is configured for Ipsec VPN.
When i check the Maximum IPsec VPN sessions,it is showing as 50 thru command
VPN# sh vpn-sessiondb summary
Active Sessions: Session Information:
LAN-to LAN :0
Peak Concurrent : 50
Remote Access :37 Concurrent Limit : 50
WebVPN :0
WebVPN Limit : 50
Email Proxy :0 Cumulative Sessions : 12890
Total Active Sessions :37 Weighted Active Load : 37
Percent Session Load : 74%
As per above statistics can u briefly explain what is Concurrent Limit : 50,
Cumulative Sessions : 12890.
Here Concurrent sessions limit showing as 50 means only 50 Users can establish VPN connection? but as per Cisco ASA 5510 can establish 250 conections.Is there any License Issue?
Pls help me regarding?
Can u explain what will be the reasons to terminates the Connection establish,Is sessions limit is a resaon?
Pls help?
Tnks
Ramu
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Tue, 06/09/2009 - 10:24
  • Green, 3000 points or more
Ramu,
Two possible reasons I can think of, one could be your firewall current license, is it base license or Sec Plus ? do show version to confirm is Sec Plus lincese.
or it could be asa code - perhaps a bug misreading the output.
RamuChichula Tue, 06/09/2009 - 19:59
It is a Base License as per Sh Version.So is it Supports only 50 Ip sec VPN Connections?
Tnks
Ramu
RamuChichula Wed, 06/10/2009 - 21:31
Pls have a look at the attachement of Version details of CiscoASA 5510 firewal which is using for VPN in our Organisation.Can we upgrade ASA5510 Version (7) to ASA 5510 version8.x,Is it effects more VPN sessions?
Kindly let me know?
Ramu
JORGE RODRIGUEZ Thu, 06/11/2009 - 10:19
Hi Steven, indeed interesting seen this and Ramu's issue, I tried loading the 7.0.7 GD code off an offline asa5510 to see output.. but box is under sec plus license, I am suspecting is code restrictions than a marketing typo .
By running 7.0.7 GD code it knocked down 100 VPN peers bringing it down from 250 to 150 limit .
This output is under version 8.0.4
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions : 2
This platform has an ASA 5510 Security Plus license.
This output is under 7.0.7 same box
Cisco Adaptive Security Appliance Software Version 7.0(7)
Compiled on Fri 06-Jul-07 10:37 by builders
System image file is "disk0:/asa707-k8.bin"
Config file at boot was "startup-config"
DRhostasa5510PRI up 3 mins 33 secs
failover cluster up 3 mins 33 secs
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : ☻CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: ♥CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : ☺CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 001f.ca97.31e8, irq 9
1: Ext: Ethernet0/1 : address is 001f.ca97.31e9, irq 9
2: Ext: Ethernet0/2 : address is 001f.ca97.31ea, irq 9
3: Ext: Ethernet0/3 : address is 001f.ca97.31eb, irq 9
4: Ext: Management0/0 : address is 001f.ca97.31ec, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Maximum VLANs : 25
Failover : Active/Standby
VPN-DES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 150
RamuChichula Sat, 06/13/2009 - 23:36
hi,
Tnks for your interest on this issue.
can we upgrade 5510 version 7.X to version 8.X,Is it support SSL VPN sessions.If supports how many connections it supports.
In ASA 5520 Version 8.X supports only 2 Webvpn and 750 Ipsec sessions ?
Tks
Ramu
RamuChichula Mon, 06/15/2009 - 04:07
Adding above issue is 5510 version 7.0 supports SSL any connect vpn sessions for vista users
Ramu
RamuChichula Mon, 06/15/2009 - 21:08
Hi all,
How to configure WEBVPN service using ASA 5510 version 7.X server.?
Is ASA 5510 version 7.X supports Anyconnect client
