Disabling Stack Ports on 3750FS switch
Jun 9th, 2009
Is there a way to disable the stack ports on the 3750FS switch? Thanks.
Alvaro Garcia Tue, 06/09/2009 - 11:50
There is not way to "turn off" the stack ports. However, just having them disconnected has the same result :o)
MUHAMMAD SHAHEEN Tue, 06/09/2009 - 15:13
Two week ago, I had to upgrade a switch stack at a customer location to the newest IOS release. While doing the upgrade, I have seen the command the command is available to disable Stackports, but i have not tried it myself.
I suggest you can try upgrading your switch and then you should be able to disable Stackports as you wish......
Hope this helps
