06-09-2009 06:42 AM - edited 03-04-2019 05:02 AM
Imagine on RouterA I have advertised all respective networks. I do not have any static routes configured (by using ip route command).
That said, is there any need to issue command "redistribute static metric <> metric-type 1 subnets"?
loopback0
ip add 10.0.0.1 255.255.255.0
s0/0
ip add 192.168.0.1 255.255.255.0
router ospf 1
network 10.0.0.0 0.0.0.255 area 0
network 192.168.0.0 0.0.0.255 area 0
Solved! Go to Solution.
06-09-2009 06:48 AM
Marlon
If you have no static routes on the router then no you do not need the "redistribute static .." statement under your "router ospf 1" as there are no statics to redistribute.
Redistributing statics is local to the router.
Jon
06-09-2009 06:48 AM
Marlon
Jon
