francisco_1 Tue, 06/09/2009 - 07:09
I beleieve you should configure it on the physical instead not configure a bandwidth statement on the Multilink interface, since it will not reflect the true bandwidth of the interface as links fail/recover. I could be wrong :)
Collin Clark Tue, 06/09/2009 - 07:22
John,
Since the serial interfaces are not configured for layer 3, it will not matter (assuming you're using the bandwidth statement for routing).
John Blakley Tue, 06/09/2009 - 08:20
Collin,
I'm actually monitoring the multilink bundle with an snmp utility. I wondered if I was getting the correct measurement, but after I posted the original message, I noticed that the bandwidth for the multilink is automatically calculated from the bandwidth of the amount of links I assume. I see the Mu1 has 3088, and I have 2 serial links at 1544. So there's not a problem with the monitoring utility :)
John
Collin Clark Tue, 06/09/2009 - 08:23
The bandwidth statement is used for routing protocol purposes only. You can always do a show interface to get the actual bandwidth of the interface.
