Not able to break the password of 3750 Switch
Jun 9th, 2009
Please help me to change the enable password of 3750 switch, I have tried renaming the config.txt, but, every time I rename it a new file gets generated.
regards,
Navinder.
navinder.singh Tue, 06/09/2009 - 08:43
I did not find any difference in password recovery process, if I take the switch standalone, which I am doing it now.
Kindly suggest
Regards.....Navinder
navinder.singh Tue, 06/09/2009 - 10:24
Kindly suggest on this as we have already done this in standalone and no avail.
Regards....Navinder
Alvaro Garcia Tue, 06/09/2009 - 11:33
Ok, so far I understand that you have a 3750 switch is a stack with a enable password that you don't know and want to change. You already did the following but still got the same issue:
-Sent the switch to rommon
-Rename the config file
-Boot the switch
-Enter to enable mode (with no password set)
-Rename the config file back to its original name
-Do copy flash:config.text system:running-config
-Enter to config t and set your own password.
One question, after doing all this do you add the switch back to the stack?
Whenever you add a switch to stack, the recently added switch takes the configuration of the current stack master switch (including the enable password).
Let me know if this is you case and I may have a solution for you.
navinder.singh Tue, 06/09/2009 - 14:29
Thanks for the information.
yes we have added the switch back to the stack.
Kindly suggest....
Alvaro Garcia Wed, 06/10/2009 - 06:22
Ok, the problem might be that when you add the switch back to the stack, it is getting the old configuration from the master stack switch.
Try this:
-Turn off all the switch stack members and just leave on the stack master.
-Do the password recovery procedure to the stack master.
-Turn on the stack member switches.
