Attendant Console License and configuration question
Jun 9th, 2009
Does an Attendant Console require DLU's??Also, will Attendant Console plug in allow the attendant to have busy-lamp fields for all 150 stations??
Jaime Valencia Tue, 06/09/2009 - 08:33
  • Cisco Employee,
  • Hall of Fame,
    2011
Old AC does not require any licensing or DLUs, just the ones for the phones you use.
New ACs have a separate licensing but still phones are the ones that use DLUs?
Which one are you going to use??
java
if this helps, please rate
shirwaziri1_2 Tue, 06/09/2009 - 09:12
Thanks for the quick feedback. I believe we are going to use Java
