Cisco ACS LDAP support
Jun 9th, 2009
Does Cisco ACS support the search scope functionality? We are trying to get ACS to go to a specific container and if the user is not found there, to search the OUs in the structure to see if it is there.
Thank you,
dpatkins Wed, 06/17/2009 - 13:04
I should clarify this. I am trying to use Cisco ACS 4.2, generic LDAP and Active Directory. My issue is that I can actually create the OU=mygroup,DC=Windows,DC=mydomain,DC=edu. I can authenticate just fine using the test aaa-server option on an ASA. What I would like to be able to do is use a wildcard in the OU so it will search through the structure to find the users that have these generic LDAP attributes:
User Directory Subtree - OU=mygroup,DC=Windows,DC=mydomain,DC=edu
Group Directory Subtree - DC=Windows,DC=mydomain,DC=edu
UserObjectType - sAMAcountName
UserObjectClass - person
GroupObjectType - cn
GroupObjectClass - group
Group Attribute Name - memberof
Basically what I would like is for it to look at the group subtree and search all the sAMAccountNames in each group in the entire structure.
Am I on the right track? I have been working on this for quite a while and I am in by no means a LDAP expert. I am not sure if I have hte correct Common LDAP Configuration for AD, but I am sure that it is pretty standard across the board.
Thank you for your help.
