ASA, inside to dmz access
Jun 9th, 2009
Hi, hope someone can help. I've been working on setting up access from some clients on the inside interface to a host on the dmz. I've been unable to get it working so far. The config is below.
ASA Version 7.0(8)
enable password Bte2XWw78iXdJmqt encrypted
passwd Bte2XWw78iXdJmqt encrypted
names
dns-guard
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.240 standby x.x.x.x
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.0.0.224 255.255.255.0 standby 10.0.0.225
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface GigabitEthernet0/3.901
vlan 901
nameif dmz
security-level 50
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.2
interface Management0/0
description LAN Failover Interface
ftp mode passive
access-list dmz-in extended permit icmp any any
access-list dmz-in extended permit ip any host 192.168.1.50 log
access-list nonat extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.255.
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
failover
failover lan unit primary
failover lan interface LANFAIL Management0/0
failover polltime unit msec 500 holdtime 5
failover polltime interface 3
failover key *****
failover interface ip LANFAIL 172.16.0.1 255.255.255.0 standby 172.16.0.2
icmp permit any inside
icmp permit any dmz
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list nonat
access-group dmz-in in interface dmz
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 10.0.0.0 255.0.0.0 10.0.0.252 1
route inside 192.168.0.0 255.255.255.0 10.0.0.252 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username administrator password 1V34C/gDgAuBFfnF encrypted privilege 15
aaa authentication ssh console LOCAL
http server enable
http 10.0.0.0 255.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh x.x.x.x 255.255.255.240 outside
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:e3c62475fae1d5ffaf08dc9b5f5a1483
: end
I can see in the log the following when the connection fails when trying icmp form the inside host 10.0.0.92 to the dmz host 192.168.1.50.
%ASA-7-609002: Teardown local-host inside:10.0.0.92 duration 0:00:02
%ASA-7-609002: Teardown local-host dmz:192.168.1.50 duration 0:00:02
Any help would be greatly appreciated.
Luis Melendrez Tue, 06/09/2009 - 10:55
Try adding the inspect icmp to the default global_policy.
ASA# config t
ASA(config)# policy-map global_policy
ASA(config-pmap)# class inspection_default
ASA(config-pmap-c)#inspec icmp
srikantganesh Tue, 06/09/2009 - 11:56
Try adding
static(inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.255.0
Recommend Updating the firewall to the latest version 8.2(1)(Not to resolve this issue but as best practice
francisco_1 Wed, 06/10/2009 - 00:22
looks like you're also missing an ACL on the inside interface
access-list inside-in extended permit ip 10.0.0.0 255.255.255.0 192.168.1.0 255.255.0.0
access-group inside-in in interface inside
francisco_1 Wed, 06/10/2009 - 00:44
this command "static(inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.255.0" uses static identity NAT for inside address 10.0.0.0 when accesss by dmz. Static identity NAT translates the real IP address to the same IP address. The translation is always active, and both "translated" and remote hosts can originate connections
kegodfrey Wed, 06/10/2009 - 01:24
Thanks for getting back with some recommendations guys. I'm still having problems accessing the DMZ from inside, icmp, rdp or otherwise. The logs are showing this info..
Any ideas? Thanks for your help.
kegodfrey Wed, 06/10/2009 - 02:48
Thanks, here is the latest config..
names
dns-guard
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
no nameif
no security-level
no ip address
vlan 901
nameif dmz
security-level 50
ftp mode passive
access-list inside-in extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.
255.0
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
failover
failover key *****
arp timeout 14400
nat-control
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
username instalec password 19VhLQJ8INTCLvRW encrypted
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
[OK]
IDG-ASA#
Kureli Sankar Wed, 06/10/2009 - 03:32
nat 0 with acl takes precedence over static identity.
You can remove this line:
Also, this line doesn't make any sense:
If the dmz host listens in port 80 or 23 try tcp connection. Although icmp should work.
sh logg | i 192.168.1.50
and see what that says.
Does 192.168.1.50 have 192.168.1.1 as its gateway?
Does this layer 3 device 10.0.0.252 have a route to the firewall in order to get to 192.168.1.0/24?
francisco_1 Wed, 06/10/2009 - 03:50
remove
access-list nonat extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.255.0
add
access-list dmz-in extended permit ip 192.168.1.0 255.0.0.0 10.0.0.0 255.255.255.0
nat (Inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
try it now.
check your routing
for interfaces directly connected to the ASA, you dont need to route for those interfaces. Make sure routing is setup properly. Post a network diagram if you have one so we can see traffic path between inside and dmz..
kegodfrey Wed, 06/10/2009 - 04:00
Thanks for the feedback. Here is the log for the 192.168.1.50 host, it does have 192.168.1.1 as its default gateway and can ping it's default gateway. The routing is in place, hosts on the 10.x subnet(s) have a route to the 192.168.1.0/24 subnet via the inside interface of the ASA.
ip route 192.168.1.0 255.255.255.0 10.0.0.224
As to how it connects, both the inside and dmz interface are connected to the same switch in different vlan's. There is vlan for DMZ, where the only route into it is via the ASA. The inside interface connects into the main VLAN, where the default gateway for the hosts on this vlan is 10.0.0.252. The host 192.168.1.50 can ping the 192.168.1.1 interface, the hosts on the LAN can ping the 10.0.0.224(inside ASA interface) Your assistance is greatly appreciated.
%ASA-6-302020: Built inbound ICMP connection for faddr 192.168.1.50/768 gaddr 19
2.168.1.1/0 laddr 192.168.1.1/0
%ASA-6-302021: Teardown ICMP connection for faddr 192.168.1.50/768 gaddr 192.168
%ASA-6-302021: Teardown ICMP connection for faddr 192.168.1.50/0 gaddr 10.0.0.92
/512 laddr 10.0.0.92/512
%ASA-7-609001: Built local-host dmz:192.168.1.50
%ASA-7-609002: Teardown local-host dmz:192.168.1.50 duration 0:00:00
%ASA-6-302020: Built outbound ICMP connection for faddr 192.168.1.50/0 gaddr 10.
0.0.92/512 laddr 10.0.0.92/512
francisco_1 Wed, 06/10/2009 - 04:10
looks like the connection is built and allowed.
is your switch doing inter-vlan routing? your ASA is routing the packets between interfaces, your vlans should be a layer vlan without SVI on the switch and just point your PC's gateway to the ASA directly..
kegodfrey Wed, 06/10/2009 - 04:18
The switch is doing inter vlan routing, but not for the dmz vlan 901. The only devices on the dmz vlan 901 are the dmz interface of the ASA and the 192.168.1.50 host. The DMZ vlan is configured only as a L2 vlan and no routed interface exists for it on the switch.
The switch is the default gateway for the 10.x hosts. I dont want to have to change the client PC's default gateway the internal ASA interface, is this necessary?
francisco_1 Wed, 06/10/2009 - 04:26
not necessary. your setup is ok.
Try adding
access-list inside-in extended permit icmp any any
francisco_1 Wed, 06/10/2009 - 04:32
your switch should have ip route 192.168.1.0 255.255.255.0 point to ASA [inside interface]
Your should only route on ASA for prefixes it doesnt know about...
remove this on ASA
remove this..
your need to be more specific when routing to inside. try and add routes for subnets again on ASA you want to route to inside..
and test.....
kegodfrey Wed, 06/10/2009 - 04:33
No, still no luck. icmp still not working... I've tried other ports, such as http and rdp that I know the host is listening on, but no connection.
kegodfrey Wed, 06/10/2009 - 04:50
Yes, I have removed the routes. The device I am trying to ping 192.168.1.50 from is on the same 10.x subnet as the inside interface as the ASA, so there are no routes other than the one outside. Still not working. Any more ideas?
francisco_1 Wed, 06/10/2009 - 05:05
pls post your config again. I want to go through it one last time...
kegodfrey Wed, 06/10/2009 - 05:12
Thanks for your help, really appreciate it.
Here is the config.
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
no nameif
no security-level
no ip address
vlan 901
nameif dmz
security-level 50
ftp mode passive
255.0
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
failover
failover key *****
arp timeout 14400
nat-control
global (dmz) 1 interface
nat (dmz) 1 192.168.1.0 255.255.255.0
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
[OK]
francisco_1 Wed, 06/10/2009 - 05:27
you still have some lines i asked you to remove above.
Copy and paste
nat (inside) 1 0.0.0.0 0.0.0.0
no global (dmz) 1 interface
no access-list nonat extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.255.0
access-list dmz-in extended permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.0.0.0
you should have
access-list inside-in extended permit ip 10.0.0.0 255.0.0.0 192.168.1.0 255.255.255.0
for testing we are permiting IP ANY ANY for now..
Kureli Sankar Wed, 06/10/2009 - 09:00
You are still only trying icmp? I see icmp built and teardown mesages. So, the conns are getting built.
Are these windows PCs. Do they have the firewall turned on? Especially the one that is supposed to reply for icmp.
If so, turn it off and try it pls.
Try some tcp connection like RDP or http or telnet.
