How to use the Console port also as Auxiliary port on 1800 Series Routers
Answered Question
Jun 9th, 2009
Is there any possibility to use the Console port at 1800 series Routers as an additional auxiliary port as I want to connect two RS232 devices to this router for remote management reasons !? This worked fine for 800 series router to convert the console port into an Aux, but I cannot find the trick for 1800 series...
Thanks a lot !
Erik
Correct Answer by Paolo Bevilacqua about 7 years 8 months ago
It is not possible to do so.
It works for the 800 because for the sake of economy, it has a single serial port only.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Tue, 06/09/2009 - 11:12
