Sub-Interfaces on 3750 and 3560 switches
Jun 9th, 2009
Has any one configured sub-Interfaces on 3750 or 3660 switches. I see the command is there, but the switch will not take the command. Here is the part number for one of the 3560s
WS-C3560G-48TS-S
Reza
Giuseppe Larosa Tue, 06/09/2009 - 09:10
Hello Reza,
on a multilayer switch you should use:
a L2 trunk carrying all required vlans
SVI L3 vlan interfaces for each L2 vlan on the trunk
Vlan based subinterfaces are used on routers interfaces
Hope to help
Giuseppe
