Sync Archive Fails
Answered Question
Jun 9th, 2009
Open up a TAC case and thought I fixed the problem. RME recognizes the device type and the OID is in there but config management can't seem to sync/collect it. When I go to search the archive it is gray out so I can't select it.
Error:
Protocol ==> Unknown / Not Applicable
CM0056 Config fetch failed for "switch" Cause: CM0204 Could not create DeviceContext for 3 Cause: CM0206 Could not get the config transport implementation for X.X.X.X Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Any ideas ?
Correct Answer by Joe Clarke about 7 years 11 months ago
No, do not delete packages. If you suspect the package repository is corrupt, you will need to talk to TAC again. There is a procedure in which they provide you a set of updated packages from a working server which you can use to rebuild your repositories.
Overall Rating: 3 (1 ratings)
Joe Clarke Tue, 06/09/2009 - 09:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
See the following thread. You have a package problem. This may not resolve the issue if your server is truly missing the required package, so you may also want to update all available RME packages from Common Services > Software Center > Device Update as well.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&topicID=.ee71a02&fromOutline=&CommCmd=MB?cmd=display_location&location=.2cd343ff
xayavongp Tue, 06/09/2009 - 11:38
What is your recommendation ? I think the packages may be corrupted. I have copied the .zips (TAC case) to the destination folders but doesn't quite work. Should I delete the packages and try reinstalling them.
I have updated all of my RME packages.
Thanks.
Correct Answer
Joe Clarke Tue, 06/09/2009 - 11:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
