VPN Concentrator Configuration File
Answered Question
Jun 9th, 2009
I have a text-based VPN Concentrator configuration file, and I want to know if there is a VPN Concentrator configuration guide that I can use to reference this file. Currently the configuration guide on cisco.com is for GUI based configuration.
Alternatively, if there is a tool/utility that will read the configuration file in GUI format without physical access to the device, that will also help.
Thanks in advance for any assistance given.
Correct Answer by slmansfield about 7 years 8 months ago
There is an "XML Export Screen" in the File Management section on the VPN concentrator. You can export the running config of the concentrator into an XML format, which provides labels and values for the fields in the configuration file.
http://www.cisco.com/en/US/docs/security/vpn3000/vpn3000_47/administration/guide/fileman.html#wpxref53361
Overall Rating: 4 (1 ratings)
steve.devera Fri, 06/12/2009 - 09:49
Not exactly what I want but definitely way better than what I was looking at previously. Thanks!
slmansfield Fri, 06/12/2009 - 12:51
I too wish there was something like what Cisco developed for the PIX for use in migrating configurations from the concentrator to the ASA platform. Thanks!
