2 ports for stateful failover
Jun 9th, 2009
Is there a need to dedicate 2 ports on the ASA to allow for a stateful failover?
According to this, the answer is yes:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#lanbas
I recall configuring this with only one port.
Jon Marshall Tue, 06/09/2009 - 12:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ron
No you don't have to. If you read the section following the diagram in the link you posted you will see that you can use the same link for both LAN and state failover.
Jon
